megabigeye
Don't ever use a single-ended (TRS) cable with a balanced output, even with a single-ended to balanced adapter-- it can cause a short within the amp/DAC/DAP/whatever you're plugging into.I have not yet tried that. I don't have a 1/4" to 2.5mm adapter for my HD650s, but that is a good idea. Since I primarily use my BTR5 with my se846s I didn't see that as an important need. I use the BTR5 in low gain mode for this use case.
Only ever use cables that are specifically designed as balanced.
(You can, however, use a balanced cable in a single-ended output with an adapter.)
