Liu Junyuan
- May 22, 2014
The reasons:
1. From his E12, an O2/Magni won't be much of an 'upgrade'.
2. People spend on intermediate products only to end up buying what they have been craving for in the beginning, so it's actually wise to have a little patience and buy a product that is a good mid-fi that can be kept for next say 5-7 years. Meanwhile, his current setup is not bad to enjoy music.
3. If only an amp's job be providing more gain then everyone would buy a O2/Magni/GD100 and never look elsewhere but that's not the case. HD650 specially is good with warm OTL amp.
I have been saving up for a LA Figaro 339 as well and wonder how much it differs from a Valhalla 2? I almost pulled the trigger on an used Ember 2 but it was sold before I got my hands on it.
I have had both side by side. I think the Valhalla 2 is a great amp, but the 339 wins for me. I ended up sending the V2 back; this is after owning the original Lyr for two years and also selling it.
The Valhalla 2 is very good. It is a very neutral OTL. It can also sound dry and lack macrodynamic slam. But in that price range, it is of the best you will find. It may be preferable to a Crack, depending on priorities. Compared to the 339, the HD650s sounded drier from the Valhalla 2 and sounded thinner. I used very high end tubes in it (75 Reflector silver shields). I found that rolling more neutral (and cheaper) tubes in the 339, I could approximate the timbre of the V2 and keep the latter's superior texture, immersion, depth, and microdynamic shading. The V2 did not really seem to change as much with tube rolling as did the 339.
Since I loved it, I had a hard time returning the V2 and only did so because I have to be choosy to afford other things. What I like about it was it's friendly plug and play kind of usability. If you wish, you can always trial it. The microdynamics, resolution, and staging were superior on the V2 to the Lyr with the HD650, though the latter excelled with macrodynamic slam. The Lyr is more ideal for planars and especially (for me) AKGs.
