Letmebefrank
- Apr 18, 2015
I'll be feeding the 650s with foobar2000 > xonar dx > toslink > Modi 2 Uber > Vali 2. I've heard good things about the 650s with the Vali 2.
Any suggestions for burn in methods? This will be the first headphones I've ever burned in and I'm not sure about the volume and type of music to play.
1. Plug them into your amp.
2. Put them on your head.
3. Pick a song
4. Press "Play"
Just listen to them. Most, if any burn-in, comes
from the pads decompressing and forming to your skull.
Yeah I'm just listening to mine; in my opinion they sound pretty ace out of the box - if they get any better that's a bonus!
or would i need a phono preamp to bring the phono signal to line level, and then use my littledot mk2/o2?
what u guys think is the best tube amp for the 650hd under 200$? i was pretty disappointed with the schiit vali 2 because it literally sounded exactly liek my o2, didn't have any tubish warmness/honey smooth sound... also i've noticed even a lot of expensive tube amps like the firefly aim to be neutral... what tube amp under 200$ would give me that nice warm honey sound? im guessing since 650hd is higher impedance, i would want an OTL tube amp right? is littledot mk2 my best bet?
also, can i go rca out from a turn table to 3.5m input into o2 or rca input to the littledot mk2? the amp will amplify the phono signal right? or would i need a phono preamp to bring the phono signal to line level, and then use my littledot mk2/o2?
Have you tried rolling a warmer sounding tube into the vali 2?
no i haven't cus i heard lot of people say its designed to be pretty neutral, but i heard that the tesla e88cc tube is good with the vali 2, do you think that is my best bet?
otherwise if i went another 100$ and got the dark voice, would that be the best bang for the buck?
