Sennheiser HD650 & Massdrop HD6XX Impressions Thread
Jan 21, 2018 at 6:42 PM Post #40,636 of 46,526
consider yourself lucky, I was getting a headache after 20-30 minutes :confounded:
The clamping pressure wouldn't be so bad if they chose a different material for the pads - but the hard memory foam is constantly pushing against your head which makes the pressure difficult to deal with for extended periods of time. The softer velour of the HD700/800 is much softer but would put your ear too close to the driver of the 650s thus changing the sound. It's pretty crazy how tightly a headphones sound is coupled to its pads, shape, size, and material choice.
Jan 21, 2018 at 6:48 PM Post #40,637 of 46,526
The area that was an issue for me was at my jaw hinge where even a little pressure for a few minutes will cause me some discomfort. For me its how and where the pressure is applied that is the issue and not the materials them selves since I can use a Grado headphone (g-pads) for hours since there is no pressure on my jaw hinge.
Jan 21, 2018 at 7:13 PM Post #40,638 of 46,526
How did you find the 800s then? I have a big head and these things touch the tip of my wisdom teeth almost all the way to the very top of my head. I've never had such large drivers on my face lol
Jan 21, 2018 at 9:58 PM Post #40,639 of 46,526
The HD800 doesn't put pressure on my jaw hinge but there is a slight hot spot at the top for me that will get uncomfortable for me after 2-3 hours so its not a big deal.
Jan 21, 2018 at 11:07 PM Post #40,640 of 46,526
The 800S put pressure on my jaw hinge muscles, but only the first few time I used them, then it went away and I find them to be the most comfortable headphones I've ever worn.
Jan 22, 2018 at 6:07 AM Post #40,642 of 46,526
OT but for 800/s user who get unequal clamling force on your head : adjust to well place and condition before use. Not like as 650, 800 has much better flex joins for auto aim and balanced force.
For 650 it clamps a bit tigter than need. So you can bend head band before each use
Jan 22, 2018 at 8:20 AM Post #40,643 of 46,526
Also the trick to put it on a basketball ball (or else) it’s so to avoid in favour to make a “U” shape to the full extended metal parts?
Jan 22, 2018 at 8:21 AM Post #40,644 of 46,526
Me too that’s why I want to loose them.
Jan 22, 2018 at 2:46 PM Post #40,645 of 46,526
I like the Dekoni ear pad memory foam because it's not hard, in fact it squishes easier than the Sennheiser stock pads. It's a very comfortable pad design/construction but it does have a different sound than the stock pads.
Jan 22, 2018 at 4:14 PM Post #40,646 of 46,526
talking about headaches, i blame all my headaches on the headphones
Anyone else feel that way? I am sure i had headaches before i was introduced to head-fi craze, but its easier to blame it on headphones, coz they wont argue back :floatsmile:
Jan 23, 2018 at 8:45 PM Post #40,648 of 46,526
I guess I am just fortunate that I like the clamping pressure of the HD650 just how it is. I have a big head as well.
Yeah same here..it almost feels like it's not even there sometimes. Must be the original cans that do all the squeezing, mine are the HD6XX Massdrop version,
Jan 23, 2018 at 8:56 PM Post #40,649 of 46,526
Mine was a regular set of Sennheiser HD 650 brand new
Jan 23, 2018 at 8:59 PM Post #40,650 of 46,526
My HD 6XX felt a little tight when I got them, and I have a small head. I used the band-flexing technique described earlier in this thread and now they feel perfect.
