Sennheiser HD650 & Massdrop HD6XX Impressions Thread
Jan 21, 2018 at 4:32 PM Post #40,621 of 46,527
Not sure. I want the Bottlehead Crack 1.1 Speedball tube amp...
They look very similar. Dark Voice reviews as best for the 600 & 650, a lot like the Crack. Zeos at YouTube does a cool vid on tube rolling using the Dark. Building a Crack sounds like a cool project.
Jan 21, 2018 at 4:49 PM Post #40,622 of 46,527
I have heard the LaFigaro 339 is a great amp for HD650.
Jan 21, 2018 at 4:49 PM Post #40,623 of 46,527
If I don’t want to bend the metal parts to loose the headband, but just make it enlarge by put it in the middle of some books or else for a couple of nights, I need to extend the metal parts all or just set them how I use it when fitting into my head?
Hope my english was clear, just want avoid to damage them.
Jan 21, 2018 at 5:13 PM Post #40,627 of 46,527
Must have made quite an impression, you've mentioned it 15 times in the last month.
Sorry about that. I will try to refrain. I want to try them on a Bottlehead Crack.
Jan 21, 2018 at 5:20 PM Post #40,628 of 46,527
Is everybody amping their HD 650s, or are there other DAPs/sources people are using?
Jan 21, 2018 at 5:29 PM Post #40,629 of 46,527
In a pinch I've used my Fiio X3 and while they get the HD650 to my listening level (65-75dB) the sound is slightly flat (less dynamic) compared to what they sound like on my Lyr2, Ember or BH Crack.
Jan 21, 2018 at 5:32 PM Post #40,630 of 46,527
After hearing them on my LPG, I am very excited to finally get to hear them on a Bottlehead Crack 1.1 Speedball amplifier.
Jan 21, 2018 at 5:35 PM Post #40,631 of 46,527
Some say just by use they will clamp less but for me I had to extend the metal sliders and bend them slightly but I tried to bend them closer to the ear cups so the sliders would still slide in and out correctly. Tyll likes to bend the center of the headband but I think this might cause the paint to crack/chip.
Jan 21, 2018 at 5:44 PM Post #40,632 of 46,527
The benefit of bending (slightly) the metal extenders is two fold; reduced wear on the pads, and better comfort due to less clamping force. I bent mine slightly and they fully extend and retract without issue. Just don't bend them straight and expect them to retract properly.
Jan 21, 2018 at 5:51 PM Post #40,633 of 46,527
Take the tips of your fingers and thumb to avoid using your whole hand then swing them in a U shape pattern to the left and right respectively. Bends them easily without worrying about putting too much pressure.
Jan 21, 2018 at 6:10 PM Post #40,634 of 46,527
I guess I am just fortunate that I like the clamping pressure of the HD650 just how it is. I have a big head as well.
