I mean, where's the line man. There's got to be a line somewhere..So I don't suppose you'd be able to listen to these headphones either :
Sennheiser HD650 & Massdrop HD6XX Impressions Thread
- Thread starter tangsta
i luvmusic 2
- Aug 27, 2013
I would say the 650 does everything better, especially making music enjoyable to listen to.Would you guys say there’s anything the HD650 does better than the LCD–2 given a very low budget for amplifying either?
RiseFall123
Hi,
I am wondering if i can use the E1 (original) with an iphone 8, will the apple camera kit (lightning to usb female) do the trick?
gug42
- Jan 29, 2008
Any recommandation between the deconi pads on massdrop ? How perform shipskin (fenestred or not) or the velour one ?
I don't find the hd6xx very confortable ... The contact point of the pads are too little thin/narrow and the clamping a little bit too strong ...
Well the sound is good, but miss some low bass and sometimes a little too bright/agressive for my taste
You can reduce the clamping force by bending the metal sliders very carefully.Any recommandation between the deconi pads on massdrop ? How perform shipskin (fenestred or not) or the velour one ?
If you find the HD650/6XX too bright/aggressive you seem to be very sensitive to treble since the HD650/6XX is rolled of in the treble or what some mistakenly call "veiled" The HD650/6XX is not known for low bass, if you want low bass you might have to look elsewhere.
raybone0566
Well the sound is good, but miss some low bass and sometimes a little too bright/agressive for my taste [/QUOTE)
raybone0566
@gug42 find it funny you own the dt990 but find the 650 bright. Funny how differently we hear things
VenturaRoyal
I think the bass region of the LCD-2 blows the HD650 out of the water but to each their own. The 650 however has a slightly more natural tone to it IMO.
VenturaRoyal
a Lohb strap and clamp relief is a must for LCD-2's. It's a cheap fix but still annoying considering how much they cost.Like @castleofargh I'd have to also agree that the weight issue of the LCD-2 (any LCD series really) is one reason that my GF and most of her friends consider it a failure, what good is the best sounding headphone if you can't enjoy it if its too heavy, keeps falling off or shifting/moving every time you move your head?
There is one sound item that to me the HD650 does better than my LCD-2f, the smoothness of the mids to relax me no matter the genre that is used.
With the LCD-2 you should also mention which version since they sound different from 2.1/2.2 > 2014 Fazor > 2016 Fazor
gug42
- Jan 29, 2008
Thank you. I will try this
Yeah i know that's why i buy it on massdrop
Not listing it any more ... I will retry it.
Well my "reference" is the lcd-x but cant own it
Thx you
I tried the Lohb strap that a friend has on his LCD-3 but even then its a bit heavy and will start to slide of my head if I look down and will start to slide if I lean back my recliner sofa to a comfortable listening position. I also have this problem to a lesser extent with TH-600. The HD650 is one of the more comfortable headphones along with the HD700 and SRH-1840.a Lohb strap and clamp relief is a must for LCD-2's. It's a cheap fix but still annoying considering how much they cost.
RiseFall123
Hi,
Before I get the Mojo dac amp in order to listening my HD650 into a secondary room only with iPhone and tidal as source, I wondering, there is an headphone in the sane price of the Mojo (500/600 eu) with a very high sensitivity that I can just plug to the iPhone and that sounds heavenly as the HD650?
Ps: i tried all the momentums and they sound worse than HD650 even without amps
Total: 24 (members: 1, guests: 23)
