Sennheiser hd555 rewiring help?
Aug 28, 2011 at 2:46 PM Thread Starter Post #1 of 1
RoskaL
Im rewiring my hd555s and want to use the splitter and will be using a 4pole 3.5mm jack plug
Whats the best way to do the split into the y? As in the strongest way to solder it? Ill be using cardas quad eutectic solder
But want it to be really neat and strong, hows the best way to be sodering? I cant find a guide specifically for this type of join
Also someone suggested Belden 1804a to use to rewire, is that a good choice?
Ill be using a hicon 3.5mm 4 pole jack and a viablue splitter with techflex braid
