Rob80b
Cable discussions are indeed a slippery slope, IMHO as long as the connectors fit securely with good contact and electricity can run freely one is good to go.Hope this isn't a silly question, but, do you feel the cable upgrade makes an audible difference compared to the default one? I've been eyeballing some clothed cables because I have cats as well and they love chewing them, something like you have would be ideal, but I'm not sure if I'm willing to spend 100€ or such just for the cable if it simply makes no difference in reality. Thanks in advance!
With the S2 I started off with a $20 6' balanced XLR from Amazon
.....but needed something longer so modded one of Sennheiser's own multi cloth bound CH800 ($389Can) with HD600 connectors,
can't really say if either cable is good or bad but results are the same.
As for cats..mine have been trained for fear of.........
