swbf2cheater
- Aug 14, 2009
Yep, I have all of them. Skip the E7 if you dont want to use the headphones with a computer, get the E11 instead.
the only time you should be using the E7 is with a computer, by itself its pretty great but comboed with the E9 its pretty amazing and an excellent deal. If you plan on a purely portable experience and dont plan to connect to a computer, then just get the E11. The E11 is pretty awesome but its not a dac, the E7 is partially an amp, and partially a dac so this really depends on what you plan to use it with.
Yes, the e7 and e9 combo is significantly better at least IMO. Considering the E9 can be purchased used for like $100 here on head fi, thats a damned great deal .
