Originally Posted by makasin /img/forum/go_quote.gif
definately a no on the ergos, I dont want to spend a large sum of money on something that looks like a headphone that was inspired by a box on the head. One reason I chose the RS2 is because I am familiar with the Grado sound (and I like it) and because of the sexy wood haha. I dont really care much for aesthetics, but it cant beo completely dumb looking.
I am kinda interested in electrostatics, but I dont know if you can get equal quality sound by getting an electrostat and the amp for 400 bucks?
You can't really judge a pair of headphones based on looks. My electrostats don't look that sexy either when you compare it to the likes of the HD580J, SR325i, K701, RS-2, etc...
You would have to bump your budget up to $433 for a set of SRS-2050A, which uses the SR-202 earspeaker and SRM-252A amp. This is the entry-level Stax set that will give you a good idea of what the electrostatic sound is really like. I haven't heard the SR-202 out of the SRM-252A, but I have out of a SRM-717 and let me tell you, the SR-202 really does impress. It doesn't quite have the bass punch, but the rest of the frequency range is detailed, refined and easy on the ears. There's a good chance you'd really like it. I'd put them in the same class as the K701/HD600 amped by a Hornet M with the differences coming down to taste. Depending on what music you like listening to (jazz, acoustic, electronic, classical, vocals), the SRS-2050A will probably be as good as whatever you're using at the moment.
I would advise against getting an aftermarket cable for the time being. Your rig is good, but still in its infancy compared to what it might blossom into later on. The aftermarket cable should be thought of as a refinement to an already mature rig. Your priorities should be headphone 1st, source 2nd, amp 3rd, cables 4th.
I haven't listened to 0404 USB, but word has it that it's a great source. Do you know for sure that the 0404 USB is better than the one you're using at the moment?
The RS-2 has pretty good resell value. It wouldn't hurt to try them out. What would be even better would be to buy from a dealer with a 30-day money back guarantee w/o a restocking fee. Give them a good week or two. If you don't like them, then just give them back for a refund.
