Jan 15, 2023 at 11:46 PM Post #11,311 of 13,798
One possible solution for 'noisy' ac power is to use an isolation transformer or a much more expensive power conditioner.
One advantage to using an isolation transformer is the output is 'balanced' (±60VAC) as this can also yield a SQ improvement in and of itself.
JJ
Jan 16, 2023 at 12:47 PM Post #11,312 of 13,798
JJ
Would something like this work?
Tripp-Lite Isolation Transformer 500W IS500HG 120V 4.4A Hospital Medical Grade
Jan 16, 2023 at 3:42 PM Post #11,313 of 13,798
Got the Yggy+ LIM in today. Very much enjoying it so far!
Got the OG A2 boards which are going to go in the old chassis so I can do a direct AB between the two, just waiting on a ROM chip to arrive currently. Currently the old chassis has the MIL boards.
The new chassis is WAYYYY easier to open and swap boards so that's great. Also did quickly check and the LIM is indeed genuine NOS so that's cool! (Kinda wish it had higher sample rate support so HQP users could stick it in NOS and take full advantage though).
Will have a video coming comparing all three.
Jan 17, 2023 at 1:23 AM Post #11,315 of 13,798
Yes, that should do the trick.
You should also be able to find non medical grade transformers, which should cost less.
And if you're handy with DIY, the core transformer can be found for well under $100.
JJ
Jan 17, 2023 at 1:18 PM Post #11,316 of 13,798
If you can, please compare SE outputs. I read Yggy OG has gimped SE outs but LIM is fine
Jan 17, 2023 at 6:35 PM Post #11,318 of 13,798
That is super news; I've been waiting patiently! 🍻
Jan 17, 2023 at 8:33 PM Post #11,320 of 13,798
Jan 20, 2023 at 1:02 PM Post #11,322 of 13,798
EDIT: nvm, issue sorted
Jan 21, 2023 at 9:11 PM Post #11,324 of 13,798
Very much looking forward to it
