Kristofa
FOFOMO!It’s fear of inevitable FOMO.
I already use the iFi Supanova cable with an upgraded fuse which makes a big difference compared to a standard power cable so I can imagine it will do the same for MIB. Is the resolution and bass greater on MIB? Soundstage the same?
You should get in the queue for the Singularity board upgrade. I'd skip MIB.Looking at my setup now, I don't have anything left to upgrade. The only thing I can think of is getting the MIB module to replace the A1. Is it worth the upgrade? Any advantages with the MIB over the A1?
Don't have to send it in unless you want everything replaced. You can order the boards and do it yourself. No difference vs upgrading to MIB from OG, right?Not as easy as to send Yggy overseas for that upgrade. Besides, MIB is an incredible sounding DAC that even I'm not sure how the Singularity would just outperform it in overall quality. Hopefully Singularity retains the MIB's incredibly liquid smooth yet very resolving sound at the same time
I'll go farther-Not as easy as to send Yggy overseas for that upgrade. Besides, MIB is an incredible sounding DAC that even I'm not sure how the Singularity would just outperform it in overall quality. Hopefully Singularity retains the MIB's incredibly liquid smooth yet very resolving sound at the same time
I guess some of us will find out later this year (yet I won't be one of them). Impressions/comparisons will be flooding in sometime after that.I'll go farther-
I'd be shocked and thoroughly flummoxed if a Delta Sigma DAC bests a Yggdrasil r2r , whether thats an OG or an LiM or a MiB. I don't believe it lol.
No other D/S DAC does so how would this new one do it?
I would be flummoxed that Schiit put themselves on a branch and sawed it off behind them given how much effort and marketing they put into MB - and the Byggy isn't arguably better.I'll go farther-
