I have a jottenheim 2 in my computer set up. It is an outstanding amp for the money. A real bargain that hits way above its reasonable price. Not a bad preamp either. Using it with my ELAC Naviis active monitors. Makes for enjoyable listening.
I am still burning the Yggdragasil Og it is now 21 days. I am thinking maybe Sunday I will hook it up to my set up. I was looking at the photos of the boards on the unit and see there is a fuse on the board. Has anyone upgraded the fuse on their Yggdragasil ? If anyone has I would appreciate any opinions or observations of the results of upgrading the fuse. The fuse rating information would also be appreciated .
Yes I have replaced the 'stock' fuse with a Synergistic Research Black fuse.
And yes it does make a noticeable improvement in my system.
Also note it requires taking the top cover off, so a deft hand and technical experience are required, especially when re-aligning the top cover during re-assembly so as to NOT strip out those tiny 4-40 screws and their seats.
Thanks for the reply. What is the fuse type(fast-slow), size (small-large) and the rating for the fuse? please . I want to order the fuse first so the info would be helpful. I think I may have a tech perform the swap. I myself like the hifi tuning supreme fuses. Thanks for the heads up about the cover removal and reassembly. I did see a you tube videos of a tech or person removing the cover it does look like a pretty involving process to do. So probably best to take it to a tech shop to do it.
I know I will like it. I have the excellent bifrost 2 dac in my computer rig and I have heard it in my main rig. It made for a pretty involving listening session . So I know I will like it based on what I have read it has a similar sound signature to the yggdragasil dac. But even better and more resolved.
Yes indeed they are sublime.
I have one -a- them in the Purp Amp just so it's all color matched…
hahahahahahahaha
But wholey wallet drain, they's expensive…
It still makes me choke when I realize I'm spending over $200, for a fuse, ya know one of them sacrificial parts that is supposed to self immolate to save other parts downstream.
And if they didn't sound wonderful they would have been returned post haste.
