the finisher
Thanks.
Other bit rates in Qobuz worked okay on Exclusive mode.
I didn't find another 192 file to sample with Qobuz before I had to leave work.
EDIT
Same file 24/192 source (Tedeschi Trucks Band - Signs) didn't work (distortion, sounded slowed down) with Wasapi (Exclusive Mode) on my home Jotunheim Multibit DAC.
EDIT #2 (Jotunheim Multibit DAC w/ Qobuz)
Norah Jones Come Away With Me (24Bit /192 kHz) same:
Wasapi - works
Wasapi (Exclusive Mode) - doesn't work
So, 24/192 works on both my Yggy and Jot, so not DAC and not USB cables.
Seems like some interaction with Qobuz at 24Bit /192 kHz & Schiit MB DACs.
EDIT #3
I downloaded the Qobuz app to my A&Futura SE100 DAP.
Tedeschi Trucks Band - Signs (24Bit /192 kHz) works.
Not sure of any "audio output setting". Just works -- apparently at 24/192.
So, seems like it isn't a source file issue
Okay Mike I tested it, and yes wasapi exclusive mode is totally borked.
It only sounds normal at 16 bit 44.1
Any high-resolution file is distorted.
when I switch out of exclusive mode and switch the bitrate manually it works just fine.
This is a Qobuz issue!
