re: displays. I hate displays with relatively useless information like bit rates or voltage on a power conditioner or volume unit output levels. I don't want any of that and indeed I cover up the LEDs on my Schiit gear now. I know some people love to obsess about such details, but all I care about is if the music is playing, and my ears will tell me that.
For me the two important things on a display have to communicate what input is being used because I use almost all of them and switch all the time, and what volume it is. Otherwise I'm in for an unpleasant surprise as I play a youtube video at Blu Ray volume levels.
That was one of my issues with the Yggy - their input selection indicators were almost impossible to tell from across the living room what it had switched to. Even if you were close to it, you had to decipher tiny heiroglyphics to know what input it was?
So my next wet dream is (how do you describe it??) a digital preamp or a “Swiss Army Knife”. This would have every common socket at the input, such as USB, coax, etc. Maybe BitWordData (BWD) to hook up with a transport. It would have at least coax and maybe BWD out as well. It would be mandatory that we have De-Jitter/re-clocking as well. It could also have slots for an optional Gadget and maybe for my other idea music processor as well. More on that in a future post. We already have such a device with a reduced feature set on the market, Eitr. Think of it as an expanded, upgradable Eitr.
Of course it's meant to be an input switcher. Why else would you have a plethora of inputs that you can use simultaneously and switch on the fly? That's what provides value is that every device you have that is digital can be increased in quality - just like with my Emotiva DACs.
I'm not the designer, of course, but I disagree. It is meant to be flexible, allowing for four different types of a single input, depending on what you use as a source. If it was a switcher it would have multiple inputs of a single type, like a preamp. It's a single input DAC, like most of them are unless they are designed with preamp functions.
Well for that rather specific definition, I guess it wasn't designed for that as it doesn't have two of the same. It's also not a preamp as it has no volume control or analog inputs.
But it definitely does switch digital inputs and can do so while all of them are simultaneously pushing digital audio. That's how I used the Gungnir MB and the DC-1.
I would call it having digital switching capability.
Also if you have say two rca coax connections, you can actually use a BNC to RCA adapter to have two rca connections. But you would have to purchase something like that.
For instance I used the BNC for my PC, the optical for my blu ray player, the coax for my Fire TV, and at one time the USB for my laptop. I switched at least 10-20 times a day depending on specifications. Hence my dissapointment because of its lack of remote. Since I have no use for a processor, I use 2 channel dacs to their maximum to be the digital processor in my living room for both entertainement and work purposes.
Whatever makes you happy I guess. But you are using it in a non-standard way. I recommend you get a digital preamp. One reason Yggdrasil doesn’t have a remote is because it’s a DAC not a switcher.
I recently Upgraded Mjolnir2 and Gumby to Yggy2(Yaggy) and a modded (upgraded capacitors) EC Aficionado. Listening through Ether Flows or Auteurs. I have no idea what the measurements are and could care less. A good drink and some well recorded music and I'm gone Baby.
Yaggy with a true tube amp with good phones is holographic. No shame in owning mid fi or entry level at all, but the next level takes the music from 2 dimensions to 3.
On Yaggy, at least compared to Gumby (so probably the great majority of DACs), it opens up the stage without being diffuse OR clinical. with a 2A3 (and I would very much assume 300B) amp and good phones listening is extremely immersive.
If Yaggy's measurements are wrong, I don't want to be right.
I've never tried my ECFs with the Yggy I have downstairs on my speaker system, but with the Holo Spring KTE 3 and Neurochrome HP-1 (solid state) or Lyr 3 + Ken Rad VT-231, good depth with the right recordings. Agreed that Jot > ECF lacks depth relative to those other amps.
I have a Yggdrasil v2 with input 1 USB, input 3 coax from Oppo DVD player.
I tried to connect my Shanling M0 DAP and I'm not getting any signal registered in the Yggy.
