snip
Could one of you who actually hears a difference consistently explain to us how this happens? It's not that I don't believe that you hear the difference, it's that I can't see how it could happen. Especially since the first thing that happens to AC is it gets converted to DC and charges up some capacitors. etc.
When I first heard that fuses made a difference I was like,
r i g h t ?!.
And until I tried it, I was skeptical too.
Really the only way to know if this helps is to try it for yourself and see.
Most of the better fuses offer a return for credit or similar policy.
I don't know of anyone who has returned a tweako fuse, but I figure the probability is that someone has.
As for an explanation on how a lowely fuse can make ANY difference, well the way I see it is…
I call this phenomonon a 'choke point' where all of the signal and/or energy and/or related information passes thru a single point. And a fuse certainly qualifies, as do power cables and interconnects and…
My point here is that a fuses job is to limit the current flow that feeds a device in case of catastrophic failure so that it doesn't completely self immolate itself.
This is double edged sword in that while protecting the downstream electronics it also can (and does) limit the ability to provide ALL of the power the circuit wants when and as it needs it.
Tweako fuses limit this power flow less than 'normal' fuses.
And to be clear we are talking about very small amounts of limitation, but since we do hear any difference, at all, tells me that we are approaching the resolution of the systems ability to not change the audio signal in any way.
And that a fuse can make an audible difference at all, is an example of the resolution of our systems.
JJ
