DoubleIPA
The Oppo UDP-205 has a remote and volume control. Yes, it's a universal disc player too, but it has a high quality audio section. Now in saying that, I firmly believe in a preamp.
The volume control is in the preamp, not the DAC. Yggdrasil is a DAC without preamp. As I said, buy a preamp for it. Schiit makes preamps. And they have a philosophy not to make combo units with a few exceptions.Any kind of volume control in a DAC unit is a form of preamp. Digital or Analog.
It's getting hard to find them without these days.
Perhaps I misunderstand, but your post implies that headphones are not affected by polarity the same way speakers are. Why would that be?Its one reason the Polarity button (like the Yggy offers) is essential. Listening in reverse polarity can cause some to miss what a good speaker setup will offer.
OK. The Wyred4Sound DAC-2v2 has a built-in preamp. From its description: "With its built-in volume control functionality, the DAC-2v2 allows audiophiles with 100% digital systems to completely eliminate the need for a pre-amp, reducing signal processing and increasing transparency. Of course, the preamp section is fully defeatable for those with preamps that they prefer to use."
A built-in preamp is different from volume control. You should be asking for a built-in preamp then.
Are you just repeating what I said? Is this one of those "Someone is wrong on the internet" moments?
PS) I wasn't the person wanting the volume control.
I wish the Yggy had a remote volume control that also included a toggle for polarity. I jump between recordings a lot and so appreciate a remote.
No, @mourip was asking for a volume control. I was arguing that DACs don't and shouldn't have volume control. After I was told that there are many examples of DACs with volume control, I asked for examples. All examples I was given were of combo units DAC+amp/preamp.@alpovs - you were the poster asking about volume controls on DACS. Not sure why you think two responders should be “asking for a built in pre-amps” when answering your question.
Semantics is very important in electronics and engineering in general. There are a significant number of combo units (DAC + amp/preamp) with volume control. But I am not aware of pure DACs (like Yggdrasil) with volume control.That said, unless we are going to play semantics, there are a significant number of DACs with remote volume control.
Yggdrasil is a pure DAC. It shouldn't have a volume control. I am always surprised when people ask for it. Now I understand that they are confusing DACs with combo units because they never had pure DACs. And I never had a combo unit.
Now you know why you might find a "polarity" switch on some recording hardware and software. The ideal is to make a recording with everyone in the same polarity. Some products may substitute the word "phase" but it means the same thing.As I mainly listen to music that has been recorded in the studio and comprised of multitracks, I'm not sure how helpful Yggy's polarity switch will be, since it's very unlikely that all of the multitracks in a given recording will have been recorded in the same polarity. Therefore reversing the polarity will make the incorrect polarity multitracks correct but will also consequently make the correct polarity multitracks incorrect. In these instances, what are the most important instruments to have in correct polarity? I presume it's more important for instruments that have high impulse/transients like percussion and less important for strings and vocals etc?
They are a dime a dozen, here are the last 3 I've had.
Ayre Codex
Resonessence Mirus Pro
Moon 230HAD
The Yggy is the first I've had in a long time that didn't have some type of preamp in it digital or analog.
DAC = Digital to Analog Converter. Yggdrasil inputs a digital signal from USB/SPDIF/AES/Coax and outputs an analog signal to RCA/XLR. It's a pure DAC, no extras. All those components are absolutely core to the DAC functionality.The Yggdrasil has connections for various data interfaces. Does that make it a DAC/USB/SPDIF/AES/Coax combo box? Wouldn’t your “pure DAC” separate those into an “interface box” and then move the power elements into a separate “transformer box”....
Just trying to understand why you would object to a volume control acting as part of a pre-amp in a DAC but not the many other supporting components that aren’t absolutely core to DAC functionality.
To be clear, I’m not asking Schiit to add a volume control to the Yggdrasil.
