- Dec 17, 2012
Doesn't look like he is using USB, he said it is connected via BNC to a RPI hat.
My Yggy has been doing this clicking every so often, also. May need to dig into this. This is with my RPi-hifiberry digi+ pro coax running RoPieee from Roon. I will do some switching around and see if I can find the cause.
Every time I reboot I get that clicking because its been disconnected and re-connects. I once had a bad (expensive) optical Toslink that did that with another DAC. Could be a bad case of drop outs coming from your USB connection. Did you try a different USB port? If you have USB 3.0 you might want to try that.. if its not a defective USB cord it may help stop it..
Try a little DeoxIT on the USB connectors? https://www.amazon.com/DeOxit-Cleaning-Solution-Spray-spray/dp/B0002BBV4G
