winders
Here is something you learn in the computer industry when computer companies try to tell you that you can't make any changes to their product. To deny a warranty claim, there has to be proof that what you changed caused the failure. So, Schiit can't really stop you from opening up your Freya or Yggdrasil and replacing the stock fuse with one of appropriate specifications.
For example:
Let's say your Yggdrasil had a USB card failure. You send it in to Schiit for repair. They notice you have an aftermarket audio fuse in place of the stock fuse. They can't deny warranty service unless they can prove that either the fuse or something you did when you installed the fuse caused the failure. Speculation is not enough.
For example:
