The only way to resolve this, since measurements appear not to show any differences, is to have a get together with 2 Yggdrasil's in a double blind listening session.
I disagree.
It isn't "The only way to resolve this", not by any stretch.
It would appear that many don't 'trust' their own hearing, especially over the long term.
And yes, for the short term, it is possible to 'trick' oneself, but in my experience living with a tweak or new piece of gear etc usually reveals much more that is substantive in terms of changes that we can perceive.
And double blind 'tests' are definitely a short term test.
I have learned that after living with a change/tweak/new piece of gear, then weeks later, go back to the way the system was before and THEN evaluate the changes.
THIS will reveal to you, in no uncertain terms, just what your experiment has yielded.
Our sense of hearing is far more sensitive than just about any testing procedure used today.
Some rely upon measurements to determine if a piece of gear is an improvement, but none of these measurements will tell you HOW a piece of gear will sound in total. And while a series of tests can point out some aspects of the SQ of gear/tweaks etc. it still requires listening to determine for oneself if the changes (if any) are desirable.
Jason has repeatedly stated that the numbers don't tell you how a piece of gear will sound. For that you need to listen for yourself to make that determination.
For myself I use the measurements as merely the 1st step in my process of evaluation of a tweak or other changes I consider.
I use measurements and design parameters as a filter to weed out the 'undesirable' choices, but without listening, over several weeks, I really can't really know if a piece of gear is an improvement or not. And this doesn't address scaleability nor if the changes are '
Better' and in which ways.
Some folks want quick and fast answers to complex questions, which usually means partial or incomplete results.
And lastly, for me anyway, this is a hobby, one where I can explore and test and try a variety of approaches to find out, for myself, what does and does not work according to my criteria.
JJ
