winders
Single ended triode refers to the amplifier design, as in single-ended vs. push-pull. It has nothing to do with balanced vs. unbalanced connections.
I would use Yggy's balanced outputs with an amp that has balanced inputs and use the balanced headphone cable.
Leotis was talking about the whether or not the design of the amp was a true differential hardware balanced design versus having balanced inputs, converting to single ended, processing, and then converting to balanced again. Yggdrasil is a true differential hardware balanced design while it appears, based on what Leotis said, the WA5 is not.
