johnjen
I have already played with ferrite chokes and have several of them on hand and a few are in use.Amazon has a very liberal return policy. I believe the two items that have the most measurable impact to a system would be a pure sine wave power conditioner (this is in no way limited to audio equipment, but highly overclocked computers and graphics cards as well) and a ferrite clamp for your USB cable (about 1 inch from the DAC input if you are using USB as your physical transport).
You seem to be pretty into modifying and optimizing your system, and I am sure you are very competent at it. As you are running in excess of $6000 worth of audio equipment, I think the cost (knowing the liberal return policy of Amazon) would be well worth the effort. Just something to consider.
-Ray
The results of using them (either positive or negative) are inconclusive, at least thus far.
As for the re-gen units I have not played with them, as I have pursued a different approach to delivering power and most significantly have performed ASCC tests, which I find much more fruitful in terms of establishing a direct correlation between SQ and power delivery.
And I have published these results in the CookBook thread.
What I have found thus far is while 'dirty power' can certainly be an issue for some, the power we have available here in Seattle is very stable and free from crud to begin with, at least at my house anyway.
In fact the transformer that feeds my house was recently replaced, and I have the shortest run (≈40') to my house and there are only 5 other houses on this branch circuit, among other near optimal ac power delivery aspects that are involved.
Thus for me a re-gen unit has a lower priority than other projects that are of more interest and I figure will yield more beneficial results in terms of sonic benefits.
Perhaps in the future I'll be able to try out a re-gen and/or balanced power delivery scheme with my system just to see if there truly is a benefit for me to my system.
But what the ASCC tests have demonstrated to me is that there is more to be gained than just what clean power and rfi suppression can deliver.
But in any event what I have learned is, if there is a CP in the chain between the source of power and the load, especially with sensitive electronics that are susceptible to 'external influences' (noise on the ground, current limiting connections, and the like), I CAN hear the difference when they are removed.
And the most recent insights we have gained is that ANY SMPS that is being used anywhere in our audio system and shares the same ac power source, has a negative effect on SQ, especially on highly tweaked systems.
And as I have chronicled previously, the fewer CP's that remain, the easier it is to hear if there are any changes as a result of performing experiments.
But I have also found that if major CP's remain in the audio playback chain, the entire system is operating at that lowest common denominator ability to function, which in turn WILL mask other CP's with less detrimental effects, such as power cables and connectors etc.
And might I mention that what I am relating here are the cumulative results of decades of trial and error experimenting which also includes my, in the field experience of service and installation and repair of industrial, commercial, and residential electrical and electronic systems.
IOW I'm not basing what I'm relating, to theory nor ideal circumstances, but real world, this is what happens over time, and what the consequences are, sorta stuff.
And since I've been at this for quite a while now, the results I'm attaining in my system attest to the efficacy of what I've learned.
JJ
