Jozurr
- Oct 25, 2009
Has anyone noticed any changes by changing the AES cable into the Yggy? is there any recommendation for a good aes cable specially if someone has compared a few of them?
I use Pro Co 3' Premium Canare AES/EBU Cable ($54.99 from Sweetwater) between SU-1 and Yggy. That cable is used for pro studio and performance work. I didn't bother with pricier "audiophile" cables, under the assumption that what the studio uses for moving the recorded bits is good enough to move the same bits before I listen to themHas anyone noticed any changes by changing the AES cable into the Yggy? is there any recommendation for a good aes cable specially if someone has compared a few of them?
I have the Mogami Gold.. it's the warmest of my AES cables. I have entry level Wireworld, DH Labs and Wireworld Gold. Copper Wireworld is a nice smooth sound, Dh Labs is more energetic but seems a bit harsh in the treble. Wireworld Gold is energetic yet smooth. Bang for the buck, I like the copper Wireworld but it's a little more relaxed. Good luck. I have all these for sale at 1/2 price of retail plus shipping (except the gold).I have been happy with Mogami Gold Studio AES . 50 some dollars. And yes it is no contest that the Yggy sounds best using AES .Thats why I have an Auralic Aries hooked up to it and not a Sonore microrendu
AES uses 2 conductors inside a shield.
Related to the current discussion about cables, I have a question. I am feeding my Yggy as follows: Roon => Raspberry Pi + Hifiberry Digi+ Pro Coax => Neutrik NADITBNC-M Coax to AES/EBU converter (75Ω -> 110Ω) => Balanced cable into AES/EBU input of my Yggy.
Is doing the conversion from coax to aes/ebu actually buying me anything? Sure, I am using the preferred input on the Yggy, but is it false comfort, since I am not really directly feeding it a balanced signal? Since I am doing the conversion with the Neutrik but starting as SE coax, would my results be the same just going into the coax input on the Yggy (or possibly better since I would remove the converter and a cable from the signal path)? I have much to learn! I just want to feed my new Yggy the best signal.
I know the simplest answer is "whatever sounds best", but I find it impossible to make that determination based on back and forth testing. I would rather know what TECHNICALLY is the best rather make myself nuts going back and forth (where my mind definitely plays tricks on me!!)
Thanks for an input and guidance you can provide!
My 2¢Related to the current discussion about cables, I have a question. I am feeding my Yggy as follows: Roon => Raspberry Pi + Hifiberry Digi+ Pro Coax => Neutrik NADITBNC-M Coax to AES/EBU converter (75Ω -> 110Ω) => Balanced cable into AES/EBU input of my Yggy.
Yeah, that is what I figured The only question is if the Yggy simply does things better with the AES input, regardless of how it got there, or if, using the transformer "drops" the quality of the signal so that any gain by using the AES input is lost. ???My 2¢
I am of the school that goes for the simpler the set up, the better.
So if there aren't ANY differences then I'd opt for SPDIF directly into the Jggy.
But technically AES is a 'Better' means of digital audio signal delivery.
But your setup, using a impedance matching transformer, isn't a 'true' AES source, so it's a bit of an apples/oranges comparison.
JJ
It's not just the input to the Jggy but the entire digital transport chain that results in 'better' SQ.Yeah, that is what I figured The only question is if the Yggy simply does things better with the AES input, regardless of how it got there, or if, using the transformer "drops" the quality of the signal so that any gain by using the AES input is lost. ???
