tlainhart
- Dec 1, 2016
if you have iOS devices, please use camera adapter kit (and a powered USB hub) to connect it directly to USB input on Yggy, that can change your perspective on MP3s. I am sure you can access Google music in iOS.
I do have a couple of iOS devices, and listen to Google Music on them. I thought that SPDIF was supposed to be better? I did try the iOS device through the CD player (it takes USB in), and then coax/SPDIF from that into Yggy. That was early on, and I didn't notice a difference at the time.
@tlainheart
I've not noticed such an effect when using my Yggy / Raggy combo (...I start to lose the detail and image.). If something like that were to happen I might suspect a power supply issue or some component overheating and drifting out of spec. Had it happen once many years ago, turned out to a be a resistor that changed value as it heated up, or that's what I was told at the time by the technician that fixed the problem. I remember reading somewhere at sometime how a power supply issue can also cause strange sound problems. Better that it should just fail altogether rather than vary from spec so much it affects the sound.
I know from my own experience that when I add a new toy to my rig I have a tendency to want to listen a little louder than usual to experience all the new revelations I'm expecting to hear based on all the conclusions I came to before I made the purchase. Listening at higher than usual levels has given me listening fatigue pretty quickly.
I listened to my Yggy with both Rag and Jot yesterday for 5 hours with no problems. I'm headphones only and CD's only. Sold my vinyl back in the late 90's when the number of digital tech pros and cons were approaching parity with the number of analogue pro and cons. It simplified my life.
Thanks - I wondered about the Rag drifting from spec, but I don't yet want to cast blame if it's me. I do hope that it is me, because I don't want to try and chase down such a technical problem. I do try to keep the volume down. There are pros and cons re analog/digital for sure, and analog complicates things, but then I listen to some of the Blue Note releases from Music Matters Jazz, and I'm OK again .
What are you using for headphones? I heard some LCD-3s the other day, and they were amazing - some day. I'm currently using Nighthawks and Grado GS1000es. I like the NH quite a bit. But I do prefer speakers.
What speakers and cd player do you use?
The CD player is a Teac CD-H750. The speakers are Polk LSi-15s. I'm looking into some bookshelves, like LS-50s.
-- Todd
