TGBerland
- Mar 3, 2017
What is the best way to go from my USB C MacBook Pro to the AES input on Yggy, I am a little confused... help would be appreciated!
I see you have responses here, but I run the following.
You need a USB-C to USB-B cable. If you follow my approach (I don't have USB-C on my computer):
- Connect this cable to the iFi Audio Micro iUSB 3.0 (active power cleaner/regenerator).
- From the iFi Audio Micro iUSB 3.0; connect via normal USB-A to USB-B cable to Audiobyte Hydra-Z (with Hydra-ZPM linear power-supply). Hydra-Z is a USB=>SPDIF/i2S converter
- From the Hydra-Z, i connect the Yggdrasil via AES/EBU.
Result; magic
if you want to go the cable route; main place to put a good cable is between iFi Audio Micro iUSB 3.0 and the Hydra Z, and make sure you are running a 110 Ohms cable for AES/EBU to the Yggdrasil. You could (like me) go wild and go for the expensive cables all the way (they make a difference; digital signals are in fact analog signals while in cable, and keep in mind: time is _not_ digital).
I have the following setup.
iMAC 27" => Nordost Heimdall2 USB => iFi Audio Micro iUSB 3.0
iFi Audio Micro iUSB 3.0 => Nordost Heimdall2 USB => Audiobyte Hydra-Z
Audiobyte Hydra-Z => Nordost Heimdall2 AES/EBU => Schiit Yggdrasil
Schiit Yggdrasil => Nordost Heimdall2 XLR => Moon 430HAD
Moon 430HAD => Nordost Heimdall2 balanced headphone cable => Audeze LCD-4 (rev2)/Audeze LCD-XC
Nordost Heimdall2 power cables all around (not the PC); and everything gets power from the ISOTEK Sigmas EVO3; which again is connected via a Nordost Heimdall2 power cable
This is pure magic; all parts have an effect - I tested for free and just ended up buying the whole cable-mess and power conditioner
