Topspin70
- Sep 12, 2012
I'm looking for a music server for my yggy. I had used Audirvana+ v2.5 on a mid 2011 iMAC and later discovered A+ to sound better through my MacBook Air. Looking at your remark that it's actually a crap transport suggests I have yet to hear what a good transport sounds like. Any suggestions for me? I'm willing to spend up to USD1,000.
Another possibility is to separate storage from streaming. Store your music on a NAS, PC, or Mac with music serving software (I use the free Minimserver on Synology NAS), and connect by Ethernet to your streamers. I have a SOtM sMS-100 (discontinued) and a Sonicorbiter SE for different systems, each sending USB to USB>coax converters with good clocks (Bel Canto mLink, discontinued). I have a new microRendu waiting at home, which is a higher end version of the same thing and should not need the converter. These gadgets need good linear power supplies to keep signal noise down (I use Teddy Pardo supplies). The advantage of separating storage from rendering is that you can use the most convenient storage without having to worry about signal quality, familiar file management and backup, and flexibility in drive choice as your library grows.
Your comment came in just when I was figuring out what are the sonore and SOTM products. Seems like quite the in thing now and pretty affordable too. So if I understand correctly these streamers to my yggy will connect via ethernet to a router? And I suppose my HDD with music should be connected to a comp that links to the router wirelessly to isolate noise travelling to the streamers? And do I control play using their respective apps?
