johnjen
Does the wiring from the power station to the transformer to your residence to your circuit breakers to your outlets matter? Or is it just the last 2.5 meters that matters?
Having done some tests and accumulated some results based upon the branch circuit from the panel in my house, and other peoples and places, branch circuits as well, I can say that the feed from the breaker box to the equipment is important.
So can the first, (or last), 6' depending upon which way you look at it, be any less important?
Again from my measurements, it is as important as well, as is the duplex receptacle, etc.
Each of these portions of the power feed can act as a 'choke point' either separately or in combination with each other.
I use an ASCC tester to measure instantaneous current delivery and have correlated these measurements with improvements in SQ.
I also hope to continue this investigation now that I have a decent scope to use.
This is gunna be great…
JJ
