Hi All, I’m bringing this up here at the invitation of Mr Rick (thanks!)
I might ask up front, has anyone tried mono Aegirs with Maggies and found them wanting as predicted by those here and elsewhere?
Doesn’t the Schiit have mono Aegirs, Vidars and a 1.7i?
Earlier, Renault 4 asked: Hi all, long time user of Schiit headphone rig (Bifrost Multibit/Valhalla2/Loki) and now planning and researching on an eventual 2-channel pre-amp/amp/speaker setup for a small, dedicated listening/office space (about 12 x 14). My purchase target date is late September, so I'm taking the time to research and audition the different components I'm thinking about.
While I have been narrowing in on a Freya+/mono Aegir/KEF LS50 combo I am interested in hearing from folks on any experience they've had with Aegir monos and Maggies (I'd say either the LRS or the .7i ideally); I listen mostly to classical piano, from solo to concerto as well as modern composers, minimalist and some latter day ambient, as well as some jazz. I am more in to presence and resolution than loudness or deep window-shaking bass. In other words, I don't get the impression I would be pushing the Aegirs out to the edge of their envelope...
I see some discussion on this here from around April '19 and have read the Stereophile review; now, with the passage of time, I'm interested to see if opinions have evolved.
thanks for your thoughts!
Crazyclhile said:This subject has come up a few times before... If you own Magneplanars, the Aegir is NOT for you. I've tried Aegir on the MMG, and it's not worth the effort beyond satisfying the curiosity of a quick experiment.
Mono Aegirs on Maggies still won't bring the power up into the range to give decent headroom. Even at low listening levels, the dynamics will be compressed. Maggies are 86dB efficient. I wouldn't consider using Aegir on anything less than 93-94 efficiency, and that will be borderline.
Dieselt said: 88db speakers are well enough for Aegir 2x
Derrick Stewart (in responding to crazychile) said: why? depends on how loud you listen, the distance from the listening place to the speakers and the placement of the speakers. I am not an engineer but I think besides the sensitivity it also has to do how difficult the load is (drops below 2 Ohm for example are hard for an amplifier i believe) I am quite sure that one Aegir will play my ATC SCM19 loud enough in my 12m2 room, speakers in corner and about 2.5meter distance. I guess about 95 dB (their max is 108dB), I think rarely get above 90dB. But that is me.
Wasn't it like this: from one watt to two watt is plus 3dB and from 2 to 4watt adds another 3dB, and so on?
Not sure though if it shall sound better than my current two mono amps. (they still work and sound fine so need to replace)
