Shini44
- Sep 22, 2012
can the Ragnarok drive the HE-6 ? i assume it can
Just placed my Order <3 and in three weeks we are going to have a three weeks vacation!!!!
then the final exams :< so studying or listening to Ragnarok, is going to be a hard choice
Congrats on your Rag.
And good luck for your final exam.
Thanks ^^ don't know how will i study with the Ragnarok in front of me XD
Yes. Very comfortably. It's my favorite HE-6 amp so far.
should i use the HE-6 with low gain? since it does have low ohms.
Probably best to experiment with what you prefer. Lower gain means it's not going to get as loud. I don't have any evidence that there's any disadvantage/advantage beyond that you may want more of the "sweet spot" (i.e. the level at which you normally listen) to be in-range of the attenuation adjustments.
usually i avoid using high gain with low ohms headphones to avoid cracking/damaging the drivers, thats why i asked around first, and always read about HE-6 needing more power, though it does have a low output impedance requirement, which confused me even more.
so i guess when i get one i can play around with low and medium gain, hmm i will see.
So does anyone in Philadelphia have a Rag?
