GEK
- Aug 30, 2007
Been using modi drivers with win 10Preview, for a few weeks now no problem.
Don't think I did anything special just installed drivers, (Schiit_USB_1_03). Its been awhile, now working with Win 10.0 Build 10240
Does anybody have an opinion on the modi together with the lyr?
Hi guys,
I've got an audioengine N2 amp and will be running Sennheiser HD650 through them. Thinking about investing in a cheap DAC one day, just wondering if the Modi 2 would be OK to run in the audioengine (or does it need to run with the magni?)
Hello! Am I correct in thinking the Modi 2 can play back 44.1kHz content natively? I ask because I use an X-Fi HD, which appears to use the same AK4396 chip, but apparently can't do 44.1kHz without resampling.
I've asked about this here: http://www.head-fi.org/t/790237/x-fi-hd-digital-music-premium-hd-query
...and it has been a pretty unsuccessful thread so far.
Can anyone shed any light on this? It is explained that the X-Fi can't do 44.1 because it is missing a 'crystal'... that I guess the Modi 2 must have?
From my understanding, Modi 2 has a 44.1 and 48 (or multiples thereof) clock, so while it may upsample/oversample, it's doing it at a whole number multiple (versus converting everything to 48k for example), which should be better.
I know I've heard of a number of SoundBlaster products resampling everything to 48kHz, but couldn't say for sure if that's what yours does. Yes, in theory that could be reducing quality, but I would also point out that there's a pretty good chance that it's completely inaudible, and personally I wouldn't use that as a reason to get a better/different DAC. I'd say the rest of the DAC design is much more likely to make a difference than whether or not it resamples everything. Unfortunately, I also can't say whether or not you'll notice any difference with the Modi 2; I would anticipate the technical measurements to be just a bit better with the Modi 2, but personally I find DAC differences rather hard to hear, so only you can find out if it makes a noticeable difference to you.
