Jul 9, 2013 at 3:46 PM Post #168 of 312
Any one know how this might sound with hd598's?
While it might sound like a flippant answer, I don't intend it as such when I say it'll sound like the HD598s. The M&M really didn't impart much of a sound of their own on anything that I tried them with, so if you enjoy the HD598 sound signature then you'd probably enjoy them with the M&M, as they'll likely sound very similar, just cleaner, clearer and with more power.
Jul 9, 2013 at 4:21 PM Post #169 of 312
are the Asgard II's outputs fixed? - or do they follow the volume pot? - if variable, do the outputs come from the output stage? - a class A SE preamp to drive my Monarchy SM70 would be icing on the cake.  Are any Asgard II owners here using it to drive a power amplifier?
Jul 9, 2013 at 4:53 PM Post #170 of 312
They follow the volume pot, but beyond that you've gone beyond what I know.
Jul 9, 2013 at 5:11 PM Post #171 of 312
thanks - I just dropped a line to Jason with a few questions - like from where is the RCA-out signal derived?/ line-out output Z?  - seems like it could make a better sounding than average preamp if one sticks to just one source and its quiet enough.  Most of my speakers run in the mid-90's to over a 100dB for one watt in the midrange.
Jul 9, 2013 at 6:58 PM Post #174 of 312
Thanks man, that's really what I'm looking for,i love the 598's and they do benefit firm an amp but the e11 isn't the best pairing for them. They just slightly change The sound Sig. A little less clarity, more bass and it is slightly looser not bad sounding some may prefer it, just not the right sound for me. :)
Jul 10, 2013 at 8:45 AM Post #175 of 312
how well does the Asgard II's relay work against turn on/off transients? does it mute fast in case of a power brownout.- outage and quick back on as often occurs before the grid goes out?
My Asgard II will be here Friday, so this is going off of my original Asgard (and Magni, and having tried a Lyr), but with the relay there's just a small click/pop through the headphones when it unmutes after you turn it on.
I don't think I had a brownout occur, but I'd assume it'd act the same as when it's turned off.
