I also have the EU version, when putting my ear directly on the chassi I can hear the humm but other then that no noticeable humm or vibrations.Clean power/DC blocker/mains conditioner can mitigate the buzz, but it won't go away completely.
Schiit Mjolnir 3 - Impressions Thread
- Thread starter XERO1
Playing with using feedback turned on while using the Mjolnir 3 as a preamp. I am going to give it a few days to see if I notice a major difference when I switch back. So far so good though.
In other news I ordered a desk fan to blow air over the pile of Schiit on my desk. It should arrive today.
artur9
- Apr 25, 2015
Someone said it sounds different if one keeps it cool with fans. Maybe you can confirm/deny that?...
On the other thread, I asked if fans could affect the sound. The fan itself, it seems, no. However the fan's power supply can feed back into the mains and affect everything. Or so they said. Maybe that's what was heard.
I will let you know. Although I have a feeling that it is not a huge difference.Someone said it sounds different if one keeps it cool with fans. Maybe you can confirm/deny that?
Mine has been a space heater for a few weeks now, so I guess that is long enough that if any differences are audible I would be able to notice them. lolSomeone said it sounds different if one keeps it cool with fans. Maybe you can confirm/deny that?
Just preference. Atrium is grander sounding in the bass with some output impedance elevation while it’s more reserved from very low OI amp. IMHO, it's not just output impedance, but full tube amp circuit along with higher output impedance do more synergetic things to Atrium while planar drivers and tube synergy needs to be a hybrid configuration to extract the absolute best out of it (e.g. Riviera AIC-10 Bal and Hifiman EF1000 to Susvara, both hybrid amps) due to planars excelling on low impedance amps
Agreed. Tubes bring their own magic, but impedance matters a lot.
Amps with high output impedance will vary their output voltage significantly as the load impedance approaches the output impedance. Dynamic headphones have an impedance peak at the resonant frequency of the driver (generally around 100 hz). A high impedance amp will tend to emphasize that resonant frequency if the overall headphone impedance is close to the output impedance of the amp. That can work really well with some headphones and not so well with others.
High output impedance affects Planar phones as well, but differently. High output impedance means the amp isn’t so good at delivering current. A lot of planars will sound compressed on high output impedance amps.
All that being said, the output impedance is so low on the MJ3 that it’s a complete non issue unless you want to color the sound from the headphones. That’s where having a high quality equalizer can be very helpful.
Agreed! That is why the first thing I wrote with go tubes or MJ3 for Atrium is preference ![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Mjolnir 3 is no longer a space heater, but as far as an audible difference not really. Maybe a whisper more clarity, and that I am chalking up to the fact that I am trying to find a difference. I tried 3 headphones I use regularly /w tracks I listen to often.
Slackaveli
This is a great and informative post. Appreciate you.Agreed. Tubes bring their own magic, but impedance matters a lot.
I got great advice on my PM by other forum user to put MJ3 on Vibrapod Cones. It reduces the buzz significantly.vibrates a bit and "sounds like a cheap refrigerator" are hardly the same thing
Thank you bro again!!
Slackaveli
oh, wow, that is a great idea. I run them on my Mentor just to provide spacing between it and my Yggy but sounds like for a Mjolnir is a must.I got great advice on my PM by other forum user to put MJ3 on Vibrapod Cones. It reduces the buzz significantly.
The MJ3’s power supply is overbuilt and picky i see, the building i live in was built about 5 years ago so i imagine there’s some sort of power filtering going on because i get zero noise and no vibration from my MJ3. When i hear of people using dc blockers and things of that nature i just think of how crazy the power supply is, it’s a boatload of transformers, chokes, and caps in there.oh, wow, that is a great idea. I run them on my Mentor just to provide spacing between it and my Yggy but sounds like for a Mjolnir is a must.
Yay! Got the FedEx notice that my MJ3 shipped! Should land about the time I’m back from traveling.
ResidentAlien
Hey. Does the Mjolnir 3 power Hifiman He6se v2 and Fostex / Modhouse T60 RP Argons well?
centuriones
Guys, how can I reduce the sibilance on the MJ3, even if it's light (but still annoying)
Total: 19 (members: 9, guests: 10)
