Hi All!
I wanted to give an update. I have started stage 2 mods, system has been down a few weeks, but I'm getting closer to being finished. These V-Cap Odams are a little larger than the low grade film caps that came out, and fitting them is a pain, requiring spacers and careful placement and extended leads.
The Audio Note silver resistors are installed, I believe these are in the tube signal path, there has to be a reason Schiit went with thru hole resistors here instead of SMD.
I decided to leave the large PS caps in, and piggy-back smaller, lower ESR electrolytics at approx 1% of the rail capacitance, then bypass that with film at approx 1% of that. So for the 680 uF 250V caps, 680uF X 2 = 1360uF, used a single 15uF electrolytic and a single .1 uF film (I did check with an ohm-meter, the PS cap pairs seem to be tied together). On the regulated rails (150V and 14V on transformer labeling) I also bypassed the smaller caps after the regulator with film. Decided not to bypass the 19V rails that I assume are the beef behind the mosfets, they have active noise cancelling and I'm not sure if I would mess something up there.
In doing the pre-out balanced output caps , I trimmed the leads too short on an electrolytic and made that cap unusable. I've had to purchase another ,ordered that tonight. I still have to start installing the 3 ODAMS on the bottom back side of the board, once everything else is in place. I'll finally need to widen the holes on the bottom plate and add one small hole.
My biggest area of concern are the small electrolytics on the bottom back of the board. leads on the 8.5V rail are awful close to the case of the cap, may need to redo that one.
Anyway, pics included, Ya'll have a great night.
Edit: sorry guys, must have been tired, cap values are now corrected, and rail voltages.
