I use high gain on GEC A2900's on my MJ2, like others have said it sounds better vs low gain. Only tubes I use low gain are ECC83, 6N2P, 6CC41 very high gain tubes.
Not sure what ECC83 I tried but the others I mentioned I could only use in my dac. Tubes never sounded right in my Schiit amps due to the very high gain on them. 6CC41 and 6N2P are basically ECC83's 6.3 volts only and ECC88 pinout.
Had a pair of those, I sold them rather quickly. A bad match with the MJ2. They make the GEC A2900 sound like a warm tube. Hope you have a better experience.
Got a new number 1, from the 12au7/ecc82 family! My beloved 7730 Long Plate Slanted Square Getters have been dethroned.
This tube does it all, and puts me there more than any other tube I have rolled so far. The Tungsram welded plates dish getters are legit! Everything is so well balanced and easy going, but dynamic and explosive at the same time, with the most detail I have heard yet. The Tungsram has got the "magic", of having delicate inner detail in the mids without ever being harsh, deep slamming subbass and sparkly highs. The vocals are stunning, and you hear all the lip smacking and little nuances in the recording. This tube makes the 7730 sound "Pedestrian", and words that come to mind are "Refined" and "Organic". The stage is as holographic and deep as it gets, with very good forward protection. Basically, the headphones disappear and I am at the venue. This is a tube I could easily recommend for any situation, due to the great balance top to bottom. In fact, the balance is so good I am able to crank up the volume, due to the tube not having any glaring spikes in the FR. This tube would sound dynamite in the MJ2.
