thyname
And you guys buy those iFi NOS 6922 tubes directly from iFi website? As a set with the adapters?
I bought then from music Direct.And you guys buy those iFi NOS 6922 tubes directly from iFi website? As a set with the adapters?
I am still a fan of the iFi NOS 6922 tubes; they are based on the JAN GE5670 which as far as I remember Mike himself has recommended. You can get them cheaper if you buy the tubes and adaptors separately but in my opinion it is worth the extra cost to get piece of mind by getting it all pre-made and ready to fit into the Mjolnir 2. They go for about $100 as well so fits right in your budget.
Guys:
Rolling tubes is really hard with MJ2. I have read about "socket savers". Any brand / type that you guys recommend?
I found these, but not sure if these are the right ones, or good enough for MJ2:
http://www.tubemonger.com/NOVIB_Socket_Saver_1960s_NOS_British_McMurdo_B9A_p/novib-mcmurdo.htm
Thanks for confirming.... I purchased those as well to use with my ordered MJ2 .. I'm hoping it is sent out soon
Guys:
Thanks everybody (on socket savers)!
I went ahead and ordered a pair from Tubemonger direct.
As for the tubes, I still wrap my head around to what I should buy, as an improvement from the MJ2 stock tubes. From Schiit site, it seems like the only options for their tube amps are:
6DJ8
6922
ECC88
6N23P
6B27
I do know NOS is preferred.
When I browse the tubes section on tubemonger, music direct, and other sites, a bunch of different names, and codes / numbers come up. Which makes me totally confused. I also noticed eBay has some of the tubes stuff at very cheap prices, although not sure of authenticity of what they sell.
I looked at the iFi stuff, but at $100 for the pair, still sounds like a lot to me, considering that I am just getting started with tubes.
So, what do I do?
Has anyone tried Amperex 7308 tubes?
rb2013 rates the Amperex 7308 highly in his tube review. Actually 2 different 60's vintage Amperex 7308 tubes make his top ten.
Upscale Audio has 1960's Amperex 7308's for $129 each (platinum grade).
Rob was specific about the year and the characteristics. It makes a difference, but since you don't have a perspective it doesn't hurt to jump in.
