@erikkkk9823 The 3.5mm to 6.3mm adapter might be the problem (some are designed to work with 3.5mm TRRS or TRRRS connections such as gaming headsets. also, does the gain switch have any effect on the distortion?
This is completely wrong. The inputs from the dac to the amp have no bearing on the outputs to the headphones. Also the Midgard isn’t a balanced amp anyway so whether you use the 1/4 or XLR, the power output is identical to the headphones.
No one's talking about using adapters bro, it's ok to use an SE DAC or XLR DAC into midgard and it's ok to use SE or XLR out to headphone. That's the point. Since we're on the topic it's also ok to have an XLR headphone cable and use a SE adapter and plug it into an amp but never the other way around. If the SE cable in question on the headphone is trrs then you need the adapter listed above to take the trrs to TRS.
You can use XLR into the amp from DAC and use SE out to headphone or vice versa if you have a SE DAC and XLR headphone cable. That doesn't matter.
Asgard 2:
Class A, single-ended MOSFET with zero negative feedback. As tubey as Solid State gets. I preferred it to a Bottlehead Crack with my DT 1990 headphones.
Measurements are solid, not class leading, but beguiling sound and enough power for 99.9% of headphones. Doubles as a preamp and mutes the output when the headphone jack is used, which I love because I don't like to turn off my power amp.
You are correct, it doesn't matter how you configure the inputs/outputs. You can mix and match as desired. I think the confusion right now amongst the group is the use of adapters to change SE to balanced and vice versa. But assuming no adapters are in use, it doesn't matter what you plug into the back and front, they don't have to match.
Yeah, the only difference is in terms of power Output, right? If you use an Balanced Dac, the volume gets louder because its an balanced chain. With an SE component in the chain, its just SE. But i think it dosent matter that mutch on the Midgard.
For my case i will use an Chord Mojo 2 with it.
There seems to be a lot of nostalgia for the Asgard 2 these days. I didn't even bother to bring mine to either of the meetups I went too this year. I figured nobody would care, plus with how hot it is didn't want to accidently burn anyone. lol.
The power of the amp itself is unchanged in all scenarios, both balanced and single ended. But you could get a higher volume if you plug in a dac that has a hotter XLR output, like the Schiit Bifrost. The Bifrost puts out 4V on XLR and 2V on RCA, so you would have a louder signal if you connected the Bifrost to the Midgard using XLR cables. But to be clear that won't affect the power of the amp itself, you'd just have a louder signal coming in. And also no matter what input you choose (RCA vs XLR), keeping the input the same, the output will be the same from the Midgard's 6.3mm and XLR outputs, because the amp it not internally balanced.
