helloh3adfi
You just lower the volume to prevent hearing damage. I think you need to turn off the amp if you pull out the cable, is that neccessary? Some people told so to prevent driver damage.
No need to power down for gain switch use.Ah, ok. Got it thanks. So i don't need to turn off the amp for changing Gain? Is there really such a difference in the gain settings? Wow, didn't know that.
Cool, thxNo need to power down for gain switch use.
- Adjust volume to low.
- Flip the gain switch to high.
- Adjust volume to comfortable level.
- Dance, within reasonable distance that the headphone cable allows for.
I prefer the high gain for my HE-X4's, and I believe the HE-500's are supposed to be a little harder to drive.So i'm currently waiting for my Schiit Magni 3+ to arrive and i have a question.
For my Hifiman HE-500 do i use the Lo or Hi gain, i guess Hi, right? And do i have to turn the amp off while switching from let's say Lo to Hi?
Yikes, Magni 3+ B started to cut out sound with HD6xx, i can hear relay clicking and sound returns then goes off again. Amp lasted like 3 months, quite meh.
Yes it should but things ended up with very un-expected turn! Played some music with Arya and it did not cut out sound, this was very confusing.Schiit's very good about service...should be under warranty -- yes?
I’m glad you found the fault and it was an easy fix! First thing I did with my HD6XX was to replace its cable with an original HD650 one bought directly from Senneheiser. Better length and no adapter requiredYes it should but things ended up with very un-expected turn! Played some music with Arya and it did not cut out sound, this was very confusing.
Played again with HD6xx and sound cutted out, wondered What is going on.
Turns out HD6xx cables 6.3mm Adaptor has gone bad, swapped other and sound went from mono like to stereo and cut out stopped. Never expected thing like this could happen and there is no fault in the amplifier.
Have you tired other amps with HD600?^ I’m using a hd600 with magni 3+ and modius (I know I’m using the modius single ended). With a minor eq change to help the sub bass. It’s amazing how enjoyable this experience is when you get the volume right on low gain. I know part of this hobby is to always look elsewhere for something better. But Schiit was right when they are basically saying this is all you need. It’s an incredible experience. I might consider getting something else someday to change the sound. But All I know is - this is special.
Not yet! Just loving this at the moment. Should I? I’ve watched a ton of reviews on other amps. I probably will try a different sound sometime soon or in next year. So many choices : )Have you tired other amps with HD600?
