winders
One of you big wigs needs to try Western Electric 396A tubes with the D getters.
You try reseating the bad tube? Or switching positions on the amp?
What is your thoughts on these, too much $$$, anyone ?
http://www.ebay.com/itm/AMPEREX-USN...-PAIR-HOLY-GRAIL-BEST-TONE-EVER-/222554331234
Those are pretty sketchy. I call them fakes. No codes, and the construction is not Holland.
I just posted these a few hours ago.
http://www.ebay.co.uk/itm/222557210740
You can get some nice vintage for less than $200.
what does authentic holland version look like? i think woo audio sells it or $200, i may just do that. too bad this ebay seller wont let me return w/o a 20% restock fee.
Do not go by the white paint on the tubes in Sammy`s post above, got a pair of 1966 Mullards that look very similar. You def wanna go by the acid etching in the pic.what does authentic holland version look like? i think woo audio sells it or $200, i may just do that. too bad this ebay seller wont let me return w/o a 20% restock fee.
The usn cep 7308 so come up on ebay from time to time under $150 per pair.@TK16
True, you can find them for ~$100 each. Depends on your time vs money ratio, and how you think you will feel if you are stuck with noisy tubes.
That's why I offered actual experience with the tube and the seller. Less risk translates to higher cost. And for some, details like matched dates, pristine looking tubes.
Here is a seller that has been offering these USN-CEP for years at $95 each:
http://audioasylumtrader.com/ca/lis...-Grade-Gold-Pin/many-of-them-available/146822
Here are two USN-CEP at $120 each on eBay:
http://www.ebay.com/itm/One-1965-Am...490703?hash=item5425be714f:g:skYAAOSw5ZBWIa3P
http://www.ebay.com/itm/One-1965-Am...487222?hash=item5425be63b6:g:qi8AAOSwo0JWIa0B
This is for the US Navy CEP version, so these tend to be a little more scarce than the PQ. That may be important to the OP. Don't know.
If you understand the process and the etch, it is true that the etch tells the story. Same tube as the PQ.
But like the Post Office CCa ink on a 6922, some do prefer the USN-CEP ink on a 6922.
