Tuneslover
Would it be wild if they put the Gadget onto one of those module cards to replace the onboard DAC....
...and self installable.
The current Gadget requires a knob...so are you going to drill a hole in your Jot case for the knob?
Hey Experts, I need your advice:
I'm 90% on getting the Jot, but do I go internal DAC or stretch my budget into a Modi MB/Jot stack to drive Aeon Flow othos via USB and Tidal HiFi streams?
RCA and XLR pre- outs can be used at the same time as both will play audio since there is no muting function on the jotunheim. Using both will not effect the quality at all so nothing to worry about. I have personally used both without any issues.Does anyone know if you can use the pre-outs for XLR and RCA can be used at the same time? Will it worsen the quality somehow or even mute one output?
Put some sort of mini knob on the card itself. But if they're doing the installing they can easily add a knob.Wouldn't there be a need for a another LED light used for the adjustment and a second hole to drill as well?
Hey, has anyone used the Jot as a preamp for a stereo power amp with no volume control on it?
I just wanted to know if I can use the Jot as a volume control on a power amp?
