For me, the inputs are the same minus the gain increase from balanced signal. Whether your DACs single ended and balanced outputs sound the same is another story.
Schiit Jotunheim Review / Preview - Head-Fi TV
- Thread starter jude
lentoviolento
- Feb 17, 2017
same story for the output...
True. Balanced output will sound different if the headphones really need the extra driver control provided by the additional power of balanced operation. Efficient headphones will just be louder.
WayTooCrazy
Anyone build one of these?
Is that 4pin XLR to TRRS? If it's balanced to anything other than balanced you'll have a very bad day.
WayTooCrazy
Your original assumption is correct. 4 pin XLR to 2.5mm TRRS A&K style.
corsiva
- Apr 9, 2017
-Bought an expensive z270 asus motherboard, SupremeFX audio, Sabre ES9023P DAC and Texas Instruments RV4580 OP-amp.
-Proceeded to hear crackle, distortions when frequency went too high or too low, and had to heavily EQ for meh sound.
-Spent 3 months researching, namely this place.
-Had Mr Speakers Aeon on my forecast, Balanced cables and all, so narrowed my criteria.
-Called Mr Speakers, and was told they use the Jotunheim in house for business.
-Spent 2 weeks going through this long long LONG thread...
-Bought the Jotunheim, and on the whim, opted not to get the internal dac but the Modi Multibit.
-Got it plugged in, was satisfied, very much so. Tested all my songs, and no distortion/crackle/static.
-2 hours later, things got better. Was more happy. Got even better after leaving it on all night.
Just wanted to say thanks for the help, all!
Currently using a humble set of Viso HP50 and they sound so much better on the new setup than the old one through onboard audio. I expect no less, but when I fired up my first game I was absolutely blown away by the difference. I had read about the Modi Multibit having high latency, and I couldn't even remotely tell anything was off.
I think, aside from the overall sound in music and gaming bring so much more crisp, that it was the soundstage and imaging that's surprised me the most. Movies with a lot of action scenes are phenomenal, as far as improvements.
MikeW
- Nov 4, 2005
I also have an asus motherboard (Z170) with Supreme Audio, and it's quite abit better then my previous motherboards, and integrated solutions. But it's no match for even the Jotunheim's internal dac. You may consider something like Regen/Recovery, or even Xmos F1 to get a bit more out of modi. I don't know what kind of difference it will make with Modi, but some have claimed improvement even with Yggy vs XMOS F1. The difference was large with jotunheim's dac.
corsiva
- Apr 9, 2017
Well I went from a z87 with the realtek 898 with the soundblaster x-fi mb3. Wasn't bad, and was all i knew. The SupremeFX did seem better, but with no EQ at all it sounded extremely muddy with the hp50's. I settled for deep and bright, for the best sound i could get from them without too much work.
The Modi MB+Jot however has no EQ going on in the system anywhere and just sounds so dang good.
I will look into the Regen/Recovery and Xmos F1. Thanks for the suggestion.
Loving the Jot. The first day of listening was just "ok." After a week, it's now "great." Anybody else has a unbalance unit where there bottom chassis isn't perfectly flat from side to side? My unit left front side sits slightly lowering than the lower right. Not a big deal unless I was pushing down the lower right corner all day, but honestly didn't expect it.
oldschool
- Aug 10, 2008
My unit is missing the bottom position markings of the front panel switches, and the switches themselves are not aligned well. Some quality control issues there, didn't expect it too but can live with it.
I would contact Schiit for a replacement. That's not normal.
FLTWS
Absolutely
WayTooCrazy
My Jot will be here on Saturday... I hope it isn't tweaked or rushed in any way. Ugh! Sorry to hear about you other guys who are noticing QC issues.
Routes
- Feb 1, 2016
Yeah, definitely contact them ASAP. That does not sound normal at all.
Total: 11 (members: 0, guests: 11)
