GearMe
- Feb 17, 2013
Sounds like the issue with with the DAC, not the amp. If you have another DAC, or even the line out on the sound card or computer, connect it directly to the line in of the Jodie. If you still get static, then it's possibly the amp.
If you think it's the DAC, try a difference USB cable, a difference USB port, or even a different computer. Finally, contact Schiit support to see if they have a solution.
It's the internal DAC. What confusing is restarting the computer fixed the problem, though I want to avoid that if possible. The USB cable is an old one I had lying around. Any recommended cables?
Nope I think this issue is Schiit related. Both my Magni2U and Vali2 pop on startup.
nerone said, "Valhalla2 had thumps on the preamplifier outputs" of which he said that "Schiit replied this was normal behavior."
Both my Magni and Vali amps pop through the preamp output (heard coming out of my powered speakers) and headphone output. With or without a DAC connected.
I like their amps but don't like this "normal behavior". I suspect it's the design because my Lake People amp doesn't do this.
Hi,
Can you tell me why the Bifrost 4490 does not suit the Jot but pair very well with the Asgard 2? Thanks
I have memory of someone trying 560 with Jot and had balanced cable, but can't seem to find the post now. Is the balanced output a big difference in quality? I'm thinking about building my own balanced cable. Trying to hear diffenence between high and low gain. For now I favour high, but can't tell why, might just be bias and the volume change.
Anyone here have an iFi Micro iCan SE and a Jot for comparison?
Would also want to hear this comparison.
Laptop streaming TIDAL > USB > Modi MB > RCA splitter cables > iCan SE/Jotunheim > HD600.
A bit off topic here, but I want to get the info out there.
Most people use asio or wasapi in Windows, but you can't do that with streaming.
I have an active triple subscription to Tidal / Google Music / Spotify. I'm a bit of streaming junky.
The two best OS for audio stack are Linux (I use Ubuntu 16.04) and iOS.
Linux is a quantum leap forward in SQ over Windows for Tidal / Google Music / Spotify, I can't recommend it enough.
