tamleo
- Jul 13, 2010
I found my Schiit dacs and amps got a great noise reduction plugged directly into wall sockets instead of multi plug power extended strips
Modius DOES have Unison@Mad Lust Envy : Unison with galvanic isolation gets rid of USB noise. Modius doesn’t have that (starts with Bifrost 2 and up).
To get rid of it you need an isolator like the Intona, but it’s expensive.
You seem to have found a work-around with XLR anyway...
Not too sure on this one. Maybe reserved for more expensive units I guess?It does have unison, however as schiit said it does not have the galvanic isolation. I assume modi 3+ does not. It's only in bifrost 2 and up I guess.
My new XLR cables came in. Everything is perfect now. No more noise through USB, perfect balance, so PYST is going back to Schiit. Maybe I'll ask for a mug and shirt as recompense
I mean, yeah, the RCA connection between the Modius and Jot 2 through USB will be noisy from my PC, but it is what it is. Not something I plan on using.
Though if I want something like a Lyr 3 as an SE only amp for my Modius, I may have to deal with this issue down the line. Eh.
Thanks for confirming what I said (with some detour).Not too sure on this one. Maybe reserved for more expensive units I guess?
First review i saw for the Jot 2
He always talks good about Schiit products as I remember
Well IMHO, yes, feeding it via xlr would be the way to go. It is primarily a balanced headphone amp and should be used that way. XLR can help with ground loops and such too as well as giving you more maximum power. The Bifrost 2 can be used either single ended or balanced with minimal loss through the SE connection as the SE connection is very good according to Jason Stoddard. With my Jot2/Bifrost2 stack, I originally had the Bifrost hooked up via XLR and it sounded amazing, however, I have since acquired a Gungnir Multibit with Unison and have hooked that up via XLR and changed the Bifrost 2 over to SE. The Bifrost 2 still sounds amazing and the Gungnir sounds awesome through the XLR outputs. The reason for this is because the SE outputs on the Gungnir are "gimped" in comparison to the XLR outs, whereas they are not on the Bifrost. Hope this helps! Looking forward to your comparison of the Jot2/Asgard 3 SE!Jot 2 dispatched!
I will be feeding it with a Bifrost 2 but wanted to check if it's better to feed it via RCA or XLR from the Bifrost 2?
My headphone use will be a mix of SE and Balanced but in terms of my permanent connection between B2 and Jot2, is it fine to keep them connected by XLR?
Going to interesting comparing the Jot 2 & Asgard 3 in SE output
He always talks good about everything he reviews... Everything's great in rainbowland!He always talks good about Schiit products as I remember
