bgentry
- Nov 12, 2014
Has anyone tried using the Bifrost MB with a preamp? I feel like the 2V output is not enough to satisfy my ears like the 4Vs coming out of my Theta. It gives my Asgard 2 more voltage swing to push my Alpha Dogs enough to where I don't get any sibilance at decent volume.
The Asgard 2, on high gain, produces full output into 32 Ohms with less than 1 Volt input. Which is a nice healthy 1 WRMS. On low gain mode, Asgard wants right around 3.75 V on it's input to produce full power. So, unless you are running in low gain mode, with relatively inefficient headphones, the Asgard 2 should have more than enough power with a DAC delivering 2V to it's inputs.
You're probably just reacting to the 6 dB of difference between the two DACs. Increased volume adds all kinds of perceptual cues that people pick up on.
OR maybe you just like the character of the Theta better. I've read several times in these forums that the Theta is slightly warmer and "fatter" sounding, particularly in the bass. That might make it sound more powerful due to slightly more bass oomph (that's a technical term. ) .
Brian.
