stjj89
- Jul 4, 2013
I'm sorry. I'm a noob with DAC's. Is the new Bifrost (AK4490) RDR as well? I'm not familiar with the term itself. Thanks.
R2R == Multibit. The "Bifrost 4490" is not a R2R DAC.
I haven't experienced any distortion, just the beginning of songs being cut off when the DAC adjusts. It's a bit of a PITA, but I just click play in foobar to start the song from the true beginning. If the song has half a second or so of silence before the music starts, it's not noticeable. I'm on Windows 7 64-bit with the latest USB driver from Schiit's site, and a Wyrd as well.
so how do the multibits sound? no one with with upgrades has commented.... have they?
any issues?
Just read the last two or three pages... again, as needed![]()
All I read are driver issues....
FWIW, I'm glad I did the upgrade, issues and all.
Is anyone having trouble with changing songs with different sample rates? Whether just using itunes or bitperfect, if I switch to a 24 96 song after a 16 41 the music is crazy distorted. Only way to fix is to flick through the manual input selector or power of and on the Bifrost. Im using latest mac os and the Wyrd as well. Strange...
I had this happen with 88.2k and 96k All other rates were fine. So I thought the driver was the issue.(WIN10) I changed the driver and wouldn't you know it, I now had issues with 44.1 but not 88.2 and 96. I did more driver install and uninstalls but no fix. Finally powered down the Multifrost, disconnected it, rebooted the laptop, reconnected the Multifrost, powered it up and all sample rates are playing fine now.
finding that going from different sample rate files, the multibit bifrost gets hung up (playing distorted, muffled, jittery, etc...). my uber card never did this in the year that i owned it.
ive been powering down the dac and pc, then all goes away for awhile. this is day 3 of this. about ready to send it back.
if everything worked with my uber shouldn't it work with my multibit? i changed nothing in my system while it was in for upgrade. so should work same right?
not getting this, and don't claim to be an expert at all this... been learning over the last year.
