MikeW
- Nov 4, 2005
Upgraded from Jotunheim Multibit to Bifrost Multibit GEN5. Was a little worried that it would be a side grade, as people say MIMBY sounds so close to BIMBY, and the Multibit module was "supposed" to equal MIMBY's performance, at least that's the impression you get from Schiit.
I've never heard a MIMBY, but I now own JOT+Multibit Module and a Bifrost Multibit GEN5. Im not going to sugar coat it here ~ the difference is stark. The multibit module is in no way competitive with Bimby. I was prepared to sell the bimby and move on if I heard no significant difference. I was rather skeptical. I won't be getting rid of the Bimby to say the least. Considering other's have stated MIMBY is close to BIMBY, I must conclude that it is also significantly better then the multibit module.
My biggest complaint with Multibit Module was treble glare, and a 2D, closed type of flat soundstage, and the inability to "keep up" with music that had alot of high frequency sound, things would sound conjested, and generally collapse. Particularly effecting POP/Electronica. Country and Classical, blues, etc sounded alot better. Bimby has dramatically better resolution/texture. I blame most of these negative traits on the module's GEN2 interface, I did also have a W4S Recovery that I used with the Multibit module and noticed significant improvements when using it. Not enough of an improvement to make me satisfied with it, but it was an improvement.
Testing the same W4S recovery with the GEN5 interface is much less obvious, I need more listening time to form any solid conclusions, with GEN2 it's immediately obvious, not so much with GEN5.
I also owned the Original GEN1 4490 Dac Module, and was not so impressed with that either. I've heard anecdotal reports that the GEN2 4490 module is a large improvement and competitive with MODI 2. Im parroting here, but I've also heard the GEN2 4490 is better than the Multibit module. I can't reccomend the Multibit module, so those who are considering upgrading the JOT's dac, don't bother, just get a Modi/Bifrost or something else entirely.
Schiit's continual move to amp/dac's is interesting. Rumour's of an Asgard 3 /w Module. They really need to get rid of GEN2 USB interface if they continue down this path. Im hopeful Mike's new USB interface will be able to fit on these module's in the future, even if they must shed the isolation of GEN5. A smaller USB input board would also allow for more room in Bifrost for a larger analog board. Be nice to get rid of Bifrost op-amps.
