Yes I have a dac.
So can you give me a link to this plz?
This is their latest version: https://www.head-fi.org/showcase/x-ddc-reserve.22320/
I have an older/cheaper one, X-DDC.
Yes I have a dac.
I need a usb to toslink adapter, what is the cleanest way to do this, need it noise free of possible, but also to have option of using the 5v USB out and not always need a LPS
What do you guys recommend, I need it to NOT have a dac
Yes I have a dac.
If the source is good there should be equally good to eitr. Now optical spdif has lower rate than coaxial.How does the Eitr fare up to connecting directly to the SPDIF ports of the Schiit DACs (especially Modi Multibit since I am using it)?
So far I am aware that the ranking seems to be
1. Unison USB
2. Eitr
3. USB Gen 2/3
Where would the SPDIF ports be in this case?
Thanks, sounds like me ordering the Eitr was the right choice, let's see if I can get the same experience as you once it comes!If the source is good there should be equally good to eitr. Now optical spdif has lower rate than coaxial.
I have the multibit and I couldn't hear a difference optical comming from my PCs sound card vs eitr that uses coaxial, but the USB sound was bad.
I got the Eitr because I can connect other devices with using USB and they all sound good.
So if source is good, I would put coaxial in the same rank with Eitr and toslink lower than coaxial but better than usb.
Saw these posts elsewhere that help to confirm that an Eitr will be better than standard PC onboard SPDIF/TOSLINK
https://www.superbestaudiofriends.o...tibit-for-the-masses.2494/page-64#post-179213
https://www.superbestaudiofriends.o...-eitr-preview-thread.4729/page-27#post-159699
Should depend on 1) quality of DAC’s implementation of optical vs coax and 2) Eitr re-clocking.
I have one for sale on eBay
https://www.ebay.co.uk/itm/Schiit-E...-/133683594220?_trksid=p2349624.m46890.l49292
