reading those posts about ssd vs hd drives improve music sound- makes no sense whatsoever. ssd is much faster sorting and sending the music files, that it I expect.There has been some posts that a SSD can sound better than a HDD. Problem is most laptops use a small SSD in combination with a larger HDD. If I was in the market for a new Win 10 laptop I would look for a 500 MB to 1 TB HDD only and 16 GB RAM.
Schiit Eitr impression and USB-SPDIF converters discussion
- Thread starter ScareDe2
uptone audio LPS 1.2 linear power supply $435 or sbooster( its huge and heavy)I am looking into linear supplies...so you have any you would recommend?
davide256
- Aug 13, 2010
I do this already with a Metrum Octave because iPhone6 is an excellent Roon endpoint. Its good for about 4-6 hours of play before iPhone battery exhaust with the USB2 version of CCK. You can also get the later USB3 CCK version which has a thunderbolt socket allowing you to connect an Ankar battery for external power and that can run for about 24 hours before battery exhaust., a good way to avoid wear and tear on the internal IPhone battery.I was thinking about installing an Eitr between my iPhone 6s and Chord Mojo. Of course, I would be using a CCK. Has anyone had any success running this combo without a powered usb hub? Has anyone had any success running this combo period?
MementoMori99
Thank you.
Elluzion
- Nov 29, 2007
Is the Eitr worth it for my setup?
the only advantage I see is going from a USB 2 to USB 5 setup, is there that much difference?
currently i have MacBook -> Modi Multibit -> Jotunheim
but i'm considering throwing the Eitr in there. Let me know what you guys think.
Adding the Eitr ahead of my Mimby worked well for me, I was more than happy with the purchase!Is the Eitr worth it for my setup?
Elluzion
- Nov 29, 2007
Awesome, thank you for sharing
DamageInc77
I also added an Eitr in front of my Modi Multibit and I'm glad I did.
I'm using an Eitr before a Brooklyn DAC+ and sound is improved over using USB in.
So, I sold my modi multibit, replaced it with a used Benchmark Dac1. And wow! Amazing sound..
I also bought a good usb-cable from Audioquest (Carbon).
If I also invest in a Eitr, meaning there will be another cable, a good spdif-cable, do you think this will improve the setup? The Benchmark is just amazing as it is, but you are always open to improvement...
Elluzion
- Nov 29, 2007
Awesome guys, I’m definitely going to get one. If anyone is looking to get rid of theirs please let me know
Zbell
Hey All - Does anyone know if the Eitr will help reduce/completely eliminate a ground loop issue I'm currently having with my set up? My PC for some reason is causing awful ground loop noise via usb (especially with my tube amp), so I'm only using optical right now. However I would love to go back to usb if possible, so I'm wondering if this will fix my problem?
@Zbell : can you describe your chain, specifically - where's the loop in your system?
Zbell
PC Mobo USB Port - Emotiva XDA-2 (recently sold - planning to get Mimby) - Bottlehead Crack - HD600s
I've isolated the PC as being the likely culprit, because when using a laptop as source I didn't get the ground loop issues.
DamageInc77
Have you tried a powered usb hub?PC Mobo USB Port - Emotiva XDA-2 (recently sold - planning to get Mimby) - Bottlehead Crack - HD600s
