So i need a RCA>RCA coax cable to work,if so can you suggest a good one?
Thank you!
Thank you!
You're welcome. Yeah, I looked up a picture of your DAC; you only need to go into the port labeled "Coaxial" on your GD DAC with an RCA coax cable. It's right under the USB B plug port. Be sure to use a proper 75 ohm SPDIF RCA digital coax cable; it will sound notably better!
Cheers, mate!
