electropop
- Apr 23, 2008
Oooooh, refurbished. I'm in ![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Just ordered this amp to go along with my new HD 650. This is my first time spending hundreds on an amp, so I hope it's going to be worth it. =\
Hi guys,
Anyone tried it with an Ipod connected to it ? I am considering buying one for the office use.
I would plug my Ipod directly into the amp......
Thanks
Denys
It works fine for that. It even comes with an adapter that plugs directly into the headphone jack on your ipod and then into the back of the Asgard. If you get a good quality Line Out Dock for your ipod, your sound quality will go up far more!
Enjoy!
Thank you...
I will probably try the B-Stock.....My Ipod is an 80g with all the music in Apple Lossless....
BTW, I am planning to use my Grado 325 with the amp......Anyone tried it? I know Senn seems to match very well, but as I have an extra pair of 325....
Thank you again
Denys
I had an opportunity to listen to the Asgard at the NJ meet. I know this has been discussed before but I still think it's worth mentioning, this amp runs very hot for a solid state amp. My GLite, that also runs in Class A, isn't nearly as hot. Even the volume knob on the Asgard was hot.
In all fairness, the Asgard runs 6 times the Class A bias of the GLite.
Grado's are groovy! The Asgard is a really sweet and mellow amp and should mate well with the 325 which can tend to be a little hot on top.
Originally Posted by kwkarth
" Thank you for setting the record straight, although, I suspect the person making the comment perhaps doesn't understand the concept, else they wouldn't have made the comment."
I conceed the fact that I don't have a grasp on that specific aspect. I also continually offer a grain of salt with what I say. What I will say is the Asgard, to my ears, didn't live up to the overwhelming hype and FOTM status. It didn't sound better than the Matrix M Stage, GLite, Headroom Micro Amp (which now runs in Class A) or Auditor to me. Those amps are not junk. No matter what, it's what sounds better to myself that means the most. No matter how it's biased.
