ozz
- Jan 23, 2007
The Asgard 3 has more than double the power of the Asgard 2 so I would think they should drive them just fine.
NiceThe Asgard 3 has more than double the power of the Asgard 2 so I would think they should drive them just fine.
Luckily the Susvara comes with stock cable 4 pin xlr.there's also Jotunheim, for double the cost of Asgard 3, that provides a bit more power (3W vs 2.5W into 50 ohms) ~ 0.8dB, but Jotunheim will require a balanced (4-pin XLR) cable for the Susvara and a balanced (XLR) source as well.
Note that using 3-wire TRS headphone cable with XLR adapter may damage the balanced amplifier.
What’s the main differences between the Asgard 3 and Magnius?Would guess the Jotunheim is a great product.
That said, if someone gave me $399 to spend on Schiit amps, I'd buy an Asgard 3 and a Magnius and put them in two different rooms...wait, I actually did that!
Allows me more flexibility in listening locations and provides me with balanced connection/power in one location and a very high value, single-ended solution in another location.
So magnius is more powerful doesn’t run as hot and more flexible right?Magnius can output balanced as well as single ended, and is op-amp based. Asgard3 is single ended only, and fully discrete (sporting the class A-“ish” Continuity topology).
Got it thanksssMagnius can output 5W@32ohms (balanced) and 2W@32ohms (single-ended), while Asgard can output 3.5W@32ohms. So it would depend on your use-case; Magnius is more powerful in balanced, but Asgard can output more power than Magnius in single-ended.
If one needs even MOAR POWAH then the Lyr3 tube hybrid can push 6W@32ohms (albeit it, as Asgard, is single-ended only).
As for hotness (as in actual temperature that is), I would think the hottest would certainly be Lyr3, followed by Asgard and as the coolest Magnius.
I pair it with the modi connected to my pc.@Green Golden Retriver
for the case of the A2 in high gain, the source will still need to provide about 1.3vrms for 1W out into 60 ohms.
What source are you using? some vintage (old-school) products used the European standard of ~700mV line outputs, so those devices will not allow full volume without an additional gain stage with Susvara.
(added)
Schiit seems to be designing their amplifiers (both headphone & speaker) to provide max power with about a 2 Vrms input.
